[GRASS-QA] GRASS QA: martinl |main.c main.c | no clones | 1 monsters |3 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Apr 21 18:12:03 EDT 2011
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 46075
ANALYSIS
your changes to files/class/methods/functions :
          File :/raster/r.out.mpeg/main.c
          Function
gee_wildfiles(Begins at: 442, Ends at:456)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      15 |       |           OK |        15 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
use_r_out(Begins at: 356, Ends at:378)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      23 |       |           OK |        23 |
Conclusion:   | this function is a            OK           |
metrics are OK
load_files(Begins at: 226, Ends at:354)
Complexity:   |      13 |     * |      WARNING |        13 |
CalledNBR:    |      39 |     * |      WARNING |        39 |
LOC:          |     129 |     * |      WARNING |       129 |
 at least 3 values are close to an outlier please consider revising code!
main(Begins at: 91, Ends at:223)
Complexity:   |      15 |     * |      WARNING |        15 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      38 |     * |      WARNING |        38 |
LOC:          |     133 |     * |      WARNING |       133 |
Clone analysis:
This file does not contain cloned functions
          File :/raster/r.fill.dir/main.c
          Function
main(Begins at: 60, Ends at:270)
Complexity:   |      14 |     * |      WARNING |        14 |
CalledNBR:    |     110 |   *** |      MONSTER |       110 |
LOC:          |     211 |    ** | BABY-MONSTER |       211 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Apr 21 18:11:50 EDT 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        65 |       147 |       230 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
