[GRASS-QA] GRASS QA: huhabla |main.c parser_wps.c | no clones | 1 monsters |1 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Mon Apr 25 14:49:22 EDT 2011
Hello huhabla,
here's a report on your recent grass-SVN change for the revision : 46103
ANALYSIS
your changes to files/class/methods/functions :
          File :/raster/r.walk/main.c
          Class
cc(Begins at: 160, Ends at:164)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Function
main(Begins at: 119, Ends at:1482)
              |          New Metrics           |Old Metrics|
Complexity:   |     213 |   *** |      MONSTER |       213 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     339 |   *** |      MONSTER |       339 |
LOC:          |    1364 |   *** |      MONSTER |      1364 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :/lib/gis/parser_wps.c
          Function
wps_print_mimetype_vector_gml212(Begins at: 828, Ends at:835)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |       8 |       |           OK |         8 |
Conclusion:   | this function is a            OK           |
metrics are OK
wps_print_mimetype_vector_gml212_appl(Begins at: 805, Ends at:812)
metrics are OK
wps_print_mimetype_vector_gml311(Begins at: 817, Ends at:824)
metrics are OK
wps_print_comlpex_input_output(Begins at: 544, Ends at:627)
Complexity:   |      17 |     * |      WARNING |        17 |
ParamNBR:     |       8 |    ** | BABY-MONSTER |         8 |
CalledNBR:    |      43 |    ** | BABY-MONSTER |        43 |
LOC:          |      84 |     * |      WARNING |        84 |
Conclusion:   | this function is a  BABY-MONSTER           |
wps_print_mimetype_vector_gml311_appl(Begins at: 794, Ends at:801)
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Mon Apr 25 14:49:13 EDT 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        65 |       147 |       230 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
