[GRASS-QA] GRASS QA: mmetz |attrb.c local_proto.h main.c | no clones | 2 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Apr 28 07:01:12 EDT 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 46119
ANALYSIS
your changes to files/class/methods/functions :
          File :/vector/v.out.ogr/attrb.c
          Function
mk_att(Begins at: 5, Ends at:152)
              |          New Metrics           |Old Metrics|
Complexity:   |      21 |    ** | BABY-MONSTER |        21 |
ParamNBR:     |       9 |   *** |      MONSTER |         9 |
CalledNBR:    |      56 |    ** | BABY-MONSTER |        56 |
LOC:          |     148 |    ** | BABY-MONSTER |       148 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :/vector/v.out.ogr/local_proto.h
          Class
Flags(Begins at: 18, Ends at:20)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
Options(Begins at: 13, Ends at:16)
Clone analysis:
          File :/vector/v.out.ogr/main.c
          Function
main(Begins at: 30, Ends at:963)
Complexity:   |     146 |   *** |      MONSTER |       146 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     373 |   *** |      MONSTER |       373 |
LOC:          |     934 |   *** |      MONSTER |       934 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Apr 28 07:01:08 EDT 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        65 |       147 |       230 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
