[GRASS-QA] GRASS QA: hamish |do_geogrid.c | no clones | 0 monsters
|3 warnings
soccerlab.info at gmail.com
Fri Feb 18 01:56:00 EST 2011
Hello hamish,
here's a report on your recent grass-SVN change for the revision : 45425
ANALYSIS
your changes to files/class/methods/functions :
File :/ps/ps.map/do_geogrid.c
Function
get_ll_bounds(Begins at: 287, Ends at:373)
| New Metrics |Old Metrics|
Complexity: | 17 | * | WARNING | 17 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 12 | | OK | 12 |
LOC: | 87 | * | WARNING | 87 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
check_coords(Begins at: 383, Ends at:441)
Complexity: | 13 | * | WARNING | 13 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 15 | | OK | 15 |
LOC: | 59 | | OK | 59 |
at least 2 values are close to an outlier please consider revising code!
do_geogrid_numbers(Begins at: 140, Ends at:258)
Complexity: | 15 | * | WARNING | 15 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 36 | * | WARNING | 36 |
LOC: | 119 | * | WARNING | 119 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Fri Feb 18 01:55:43 EST 2011 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 66 | 148 | 231 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
