[GRASS-QA] GRASS QA: neteler |local_proto.h ascii.c main.c args.c
...| no clones | 2 monsters |1 warnings
soccerlab.info at gmail.com
Wed Feb 23 11:50:40 EST 2011
Hello neteler,
here's a report on your recent grass-SVN change for the revision : 45454
ANALYSIS
your changes to files/class/methods/functions :
File :/vector/v.out.ascii/local_proto.h
The system don't find class, method and function
in this file during analysis!
File :/lib/vector/Vlib/ascii.c
Function
Vect_write_ascii(Begins at: 284, Ends at:655)
| New Metrics |Old Metrics|
Complexity: | 75 | *** | MONSTER | 75 |
ParamNBR: | 12 | *** | MONSTER | 12 |
CalledNBR: | 118 | *** | MONSTER | 118 |
LOC: | 372 | *** | MONSTER | 372 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :/vector/v.out.ascii/main.c
Function
main(Begins at: 30, Ends at:142)
Complexity: | 21 | ** | BABY-MONSTER | 21 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 51 | ** | BABY-MONSTER | 51 |
LOC: | 113 | * | WARNING | 113 |
Conclusion: | this function is a BABY-MONSTER |
Clone analysis:
File :/vector/v.out.ascii/args.c
Function
parse_args(Begins at: 10, Ends at:119)
Complexity: | 13 | * | WARNING | 13 |
ParamNBR: | 13 | *** | MONSTER | 13 |
CalledNBR: | 47 | ** | BABY-MONSTER | 47 |
LOC: | 110 | * | WARNING | 110 |
Clone analysis:
File :/include/vector.h
____________________________________________
Threshold grass key metrics values at Wed Feb 23 11:50:32 EST 2011 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 66 | 148 | 231 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
