[GRASS-QA] GRASS QA: mmetz |break_polygons.c | no clones | 2 monsters |1 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Jan 4 05:21:08 EST 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 44859
ANALYSIS
your changes to files/class/methods/functions :
          File :/lib/vector/Vlib/break_polygons.c
          Function
compare_xpnts(Begins at: 83, Ends at:105)
              |          New Metrics           |Old Metrics|
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      23 |       |           OK |        23 |
Conclusion:   | this function is a            OK           |
metrics are OK
Vect_break_polygons_mem(Begins at: 400, Ends at:650)
Complexity:   |      29 |    ** | BABY-MONSTER |        29 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      56 |    ** | BABY-MONSTER |        56 |
LOC:          |     251 |   *** |      MONSTER |       251 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
srch(Begins at: 77, Ends at:80)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
Vect_break_polygons(Begins at: 672, Ends at:679)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |       8 |       |           OK |         8 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Vect_break_polygons_file(Begins at: 108, Ends at:396)
CalledNBR:    |      88 |   *** |      MONSTER |        88 |
LOC:          |     289 |   *** |      MONSTER |       289 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Jan 04 05:21:05 EST 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        65 |       146 |       227 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
