[GRASS-QA] GRASS QA: mmetz |spindex_rw.c | no clones | 0 monsters
|3 warnings
soccerlab.info at gmail.com
Tue Jan 11 13:03:21 EST 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 44954
ANALYSIS
your changes to files/class/methods/functions :
File :/lib/vector/diglib/spindex_rw.c
Class
spidxstack(Begins at: 665, Ends at:670)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Function
dig_dump_spidx(Begins at: 1230, Ends at:1269)
| New Metrics |Old Metrics|
Complexity: | 5 | | OK | 5 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 16 | | OK | 16 |
LOC: | 40 | | OK | 40 |
Conclusion: | this function is a OK |
metrics are OK
rtree_dump_node(Begins at: 522, Ends at:549)
Complexity: | 6 | | OK | 6 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 28 | | OK | 28 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
rtree_dump_branch_file(Begins at: 563, Ends at:580)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 18 | | OK | 18 |
rtree_dump_node_file(Begins at: 592, Ends at:621)
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 30 | | OK | 30 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Jan 11 13:03:15 EST 2011 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 65 | 146 | 227 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
