[GRASS-QA] GRASS QA: martinl |parse.c main.c print.c parser_standard_options.c ...| no clones | 2 monsters |5 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Sat Jan 15 18:59:26 EST 2011
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 45050
ANALYSIS
your changes to files/class/methods/functions :
          File :/vector/v.info/parse.c
          Function
parse_args(Begins at: 6, Ends at:62)
              |          New Metrics           |Old Metrics|
Complexity:   |       7 |       |           OK |         7 |
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      57 |       |           OK |        57 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :/vector/v.info/main.c
          Function
main(Begins at: 26, Ends at:99)
Complexity:   |      12 |     * |      WARNING |        12 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      30 |     * |      WARNING |        30 |
LOC:          |      74 |     * |      WARNING |        74 |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
Clone analysis:
          File :/vector/v.info/print.c
          Function
print_shell(Begins at: 167, Ends at:224)
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      43 |    ** | BABY-MONSTER |        43 |
LOC:          |      58 |       |           OK |        58 |
print_topo(Begins at: 44, Ends at:114)
Complexity:   |       3 |       |           OK |         3 |
LOC:          |      71 |     * |      WARNING |        71 |
print_info(Begins at: 226, Ends at:392)
CalledNBR:    |     145 |   *** |      MONSTER |       145 |
LOC:          |     167 |    ** | BABY-MONSTER |       167 |
Conclusion:   | this function is a       MONSTER           |
print_columns(Begins at: 116, Ends at:165)
ParamNBR:     |       3 |     * |      WARNING |         3 |
LOC:          |      50 |       |           OK |        50 |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
          File :/lib/gis/parser_standard_options.c
          Function
G_define_standard_option(Begins at: 94, Ends at:484)
Complexity:   |      44 |   *** |      MONSTER |        44 |
CalledNBR:    |      55 |    ** | BABY-MONSTER |        55 |
LOC:          |     391 |   *** |      MONSTER |       391 |
Clone analysis:
          File :/vector/v.info/local_proto.h
The system don't find class, method and function
 in this file during analysis!
____________________________________________
Threshold grass key metrics values at Sat Jan 15 18:59:14 EST 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        66 |       148 |       231 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
