[GRASS-QA] GRASS QA: mmetz |main.c misc.c | no clones | 1 monsters |2 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Mon Jan 24 09:49:12 EST 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 45172
ANALYSIS
your changes to files/class/methods/functions :
          File :/vector/v.generalize/main.c
          Function
main(Begins at: 43, Ends at:520)
              |          New Metrics           |Old Metrics|
Complexity:   |      62 |   *** |      MONSTER |        62 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     154 |   *** |      MONSTER |       154 |
LOC:          |     478 |   *** |      MONSTER |       478 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :/vector/v.generalize/misc.c
          Function
parse_filter_options(Begins at: 193, Ends at:252)
Complexity:   |      13 |     * |      WARNING |        13 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |      22 |     * |      WARNING |        22 |
LOC:          |      60 |       |           OK |        60 |
Conclusion:   | this function is a  BABY-MONSTER           |
type_mask(Begins at: 26, Ends at:44)
Complexity:   |       6 |       |           OK |         6 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      19 |       |           OK |        19 |
Conclusion:   | this function is a            OK           |
metrics are OK
get_furthest(Begins at: 46, Ends at:75)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      30 |       |           OK |        30 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Clone analysis:
____________________________________________
Threshold grass key metrics values at Mon Jan 24 09:49:03 EST 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        65 |       146 |       227 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
