[GRASS-QA] GRASS QA: mmetz |buffer2.c | no clones | 1 monsters |0
warnings
soccerlab.info at gmail.com
Tue Jan 25 05:17:09 EST 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 45179
ANALYSIS
your changes to files/class/methods/functions :
File :/lib/vector/Vlib/buffer2.c
Function
Vect_area_buffer2(Begins at: 1019, Ends at:1071)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 11 | *** | MONSTER | 11 |
CalledNBR: | 17 | * | WARNING | 17 |
LOC: | 53 | | OK | 53 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Jan 25 05:17:06 EST 2011 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 65 | 146 | 227 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
