[GRASS-QA] GRASS QA: martinl |parser.c parser_local_proto.h | no clones | 1 monsters |7 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Jan 26 18:18:07 EST 2011
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 45212
ANALYSIS
your changes to files/class/methods/functions :
          File :/lib/gis/parser.c
          Function
check_required(Begins at: 1156, Ends at:1176)
              |          New Metrics           |Old Metrics|
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      21 |       |           OK |        21 |
Conclusion:   | this function is a            OK           |
metrics are OK
set_option(Begins at: 890, Ends at:954)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |      16 |       |           OK |        16 |
LOC:          |      65 |     * |      WARNING |        65 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
check_string(Begins at: 1131, Ends at:1154)
Complexity:   |       9 |     * |      WARNING |         9 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      24 |       |           OK |        24 |
append_error(Begins at: 1385, Ends at:1389)
Complexity:   |       1 |       |           OK |         1 |
LOC:          |       5 |       |           OK |         5 |
metrics are OK
check_an_opt(Begins at: 988, Ends at:1042)
Complexity:   |      12 |     * |      WARNING |        12 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
LOC:          |      55 |       |           OK |        55 |
check_opts(Begins at: 956, Ends at:986)
Complexity:   |       7 |       |           OK |         7 |
LOC:          |      31 |       |           OK |        31 |
metrics are OK
split_opts(Begins at: 1178, Ends at:1233)
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      56 |       |           OK |        56 |
 at least 1 values are close to an outlier please consider revising code!
check_int(Begins at: 1044, Ends at:1085)
Complexity:   |      13 |     * |      WARNING |        13 |
ParamNBR:     |       2 |       |           OK |         2 |
LOC:          |      42 |       |           OK |        42 |
split_gisprompt(Begins at: 1357, Ends at:1383)
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      27 |       |           OK |        27 |
contains(Begins at: 841, Ends at:849)
Complexity:   |       3 |       |           OK |         3 |
LOC:          |       9 |       |           OK |         9 |
metrics are OK
match_option(Begins at: 884, Ends at:888)
metrics are OK
check_overwrite(Begins at: 1272, Ends at:1355)
Complexity:   |      17 |     * |      WARNING |        17 |
CalledNBR:    |      21 |     * |      WARNING |        21 |
LOC:          |      84 |     * |      WARNING |        84 |
 at least 3 values are close to an outlier please consider revising code!
is_option(Begins at: 851, Ends at:856)
LOC:          |       6 |       |           OK |         6 |
metrics are OK
check_multiple_opts(Begins at: 1235, Ends at:1269)
Complexity:   |       8 |       |           OK |         8 |
LOC:          |      35 |       |           OK |        35 |
metrics are OK
set_flag(Begins at: 808, Ends at:836)
Complexity:   |       5 |       |           OK |         5 |
LOC:          |      29 |       |           OK |        29 |
metrics are OK
module_gui_wx(Begins at: 794, Ends at:806)
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      13 |       |           OK |        13 |
metrics are OK
G_parser(Begins at: 311, Ends at:583)
Complexity:   |      45 |   *** |      MONSTER |        45 |
CalledNBR:    |      95 |   *** |      MONSTER |        95 |
LOC:          |     273 |   *** |      MONSTER |       273 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :/lib/gis/parser_local_proto.h
          Class
Item(Begins at: 7, Ends at:12)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
state(Begins at: 14, Ends at:42)
Clone analysis:
____________________________________________
Threshold grass key metrics values at Wed Jan 26 18:17:56 EST 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        65 |       146 |       227 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
