[GRASS-QA] GRASS QA: mmetz |main.c | 2 clones | 1 monsters |1 warnings
soccerlab.info at gmail.com
Thu Jan 27 09:40:17 EST 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 45219
ANALYSIS
your changes to files/class/methods/functions :
File :/vector/v.buffer/main.c
Class
buf_contours(Begins at: 71, Ends at:76)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Function
adjust_tolerance(Begins at: 37, Ends at:47)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 11 | | OK | 11 |
Conclusion: | this function is a OK |
metrics are OK
main(Begins at: 106, Ends at:637)
Complexity: | 61 | *** | MONSTER | 61 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 216 | *** | MONSTER | 216 |
LOC: | 532 | *** | MONSTER | 532 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
db_CatValArray_get_value_di(Begins at: 49, Ends at:69)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 3 | * | WARNING | 3 |
LOC: | 21 | | OK | 21 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file has 2 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/vector/v.buffer/main.c clones of adjust_tolerance are:
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.buffer/main.c adjust_tolerance
In /data/project-manager/grass/grassSVN/grass/trunk/vector/v.buffer/main.c clones of db_CatValArray_get_value_di are:
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.buffer/main.c db_CatValArray_get_value_di
____________________________________________
Threshold grass key metrics values at Thu Jan 27 09:40:10 EST 2011 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 65 | 146 | 227 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
