[GRASS-QA] GRASS QA: martinl |read_key.c local_proto.h main.c r_instructions.c | no clones | 2 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Sun Mar 6 06:59:45 EST 2011
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 45585
ANALYSIS
your changes to files/class/methods/functions :
          File :/ps/ps.map/read_key.c
The system don't find class, method and function
 in this file during analysis!
          File :/ps/ps.map/local_proto.h
          File :/ps/ps.map/main.c
          Function
main(Begins at: 70, Ends at:282)
              |          New Metrics           |Old Metrics|
Complexity:   |      15 |     * |      WARNING |        15 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      81 |   *** |      MONSTER |        81 |
LOC:          |     213 |    ** | BABY-MONSTER |       213 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :/ps/ps.map/r_instructions.c
          Function
read_instructions(Begins at: 30, Ends at:464)
Complexity:   |      85 |   *** |      MONSTER |        85 |
ParamNBR:     |       9 |   *** |      MONSTER |         9 |
CalledNBR:    |     140 |   *** |      MONSTER |       140 |
LOC:          |     435 |   *** |      MONSTER |       435 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Sun Mar 06 06:59:40 EST 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        16 |        38 |        61 |
LOC:                  |        64 |       145 |       226 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
