[GRASS-QA] GRASS QA: martinl |error.c value.c driver_state.c d_close_cur.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Mar 15 13:51:50 EDT 2011
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 45673
ANALYSIS
your changes to files/class/methods/functions :
          File :/lib/db/dbmi_base/error.c
          Function
db_set_error_who(Begins at: 33, Ends at:38)
              |          New Metrics           |Old Metrics|
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       6 |       |           OK |         6 |
Conclusion:   | this function is a            OK           |
metrics are OK
db_error(Begins at: 57, Ends at:68)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      12 |       |           OK |        12 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :/lib/db/dbmi_base/value.c
          Function
db_CatValArray_free(Begins at: 348, Ends at:364)
Complexity:   |       5 |       |           OK |         5 |
LOC:          |      17 |       |           OK |        17 |
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_driver/driver_state.c
          Function
db__mark_database_closed(Begins at: 67, Ends at:72)
Complexity:   |       1 |       |           OK |         1 |
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_driver/d_close_cur.c
          Function
db_d_close_cursor(Begins at: 26, Ends at:58)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |      10 |       |           OK |        10 |
LOC:          |      33 |       |           OK |        33 |
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Mar 15 13:51:40 EDT 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        16 |        38 |        61 |
LOC:                  |        64 |       145 |       226 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
