[GRASS-QA] GRASS QA: hamish |main.c r_info.c map_info.h map_info.c
| no clones | 1 monsters |2 warnings
soccerlab.info at gmail.com
Sat Mar 26 22:13:41 EDT 2011
Hello hamish,
here's a report on your recent grass-SVN change for the revision : 45775
ANALYSIS
your changes to files/class/methods/functions :
File :/ps/ps.map/main.c
Function
main(Begins at: 70, Ends at:280)
| New Metrics |Old Metrics|
Complexity: | 15 | * | WARNING | 15 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 81 | *** | MONSTER | 81 |
LOC: | 211 | ** | BABY-MONSTER | 211 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :/ps/ps.map/r_info.c
Function
read_info(Begins at: 25, Ends at:113)
Complexity: | 18 | * | WARNING | 18 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 29 | * | WARNING | 29 |
LOC: | 89 | * | WARNING | 89 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
File :/ps/ps.map/map_info.h
Class
map_info(Begins at: 8, Ends at:14)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | | | | | | |
Clone analysis:
File :/ps/ps.map/map_info.c
Function
map_info(Begins at: 9, Ends at:110)
Complexity: | 10 | * | WARNING | 10 |
CalledNBR: | 35 | * | WARNING | 35 |
LOC: | 102 | * | WARNING | 102 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Sat Mar 26 22:13:27 EDT 2011 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 21 | 33 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 16 | 38 | 61 |
LOC: | 64 | 145 | 226 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
