[GRASS-QA] GRASS QA: martinl |gis.h proj1.c proj3.c proj2.c | no clones | 0 monsters |1 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed May 4 15:38:21 EDT 2011
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 46187
ANALYSIS
your changes to files/class/methods/functions :
          File :/include/gis.h
          Class
Cell_head(Begins at: 258, Ends at:280)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
Counter(Begins at: 378, Ends at:380)
          Class
Flag(Begins at: 351, Ends at:360)
          Class
GModule(Begins at: 362, Ends at:370)
          Class
G_3dview(Begins at: 285, Ends at:310)
          Class
Key_Value(Begins at: 312, Ends at:318)
          Class
Option(Begins at: 320, Ends at:349)
|NEW Metrics |      1 |      0 |      0 |      1 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      1 |      0 |      0 |
          Class
Popen(Begins at: 382, Ends at:385)
          Class
TimeStamp(Begins at: 372, Ends at:376)
Clone analysis:
This file does not contain cloned functions
          File :/lib/gis/proj1.c
The system don't find class, method and function
 in this file during analysis!
          File :/lib/gis/proj3.c
          Function
init(Begins at: 26, Ends at:35)
              |          New Metrics           |Old Metrics|
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      10 |       |           OK |        10 |
Conclusion:   | this function is a            OK           |
metrics are OK
G_database_unit_name(Begins at: 48, Ends at:79)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      32 |       |           OK |        32 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
          File :/lib/gis/proj2.c
          Function
G__projection_units(Begins at: 31, Ends at:46)
Complexity:   |       7 |       |           OK |         7 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      16 |       |           OK |        16 |
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Wed May 04 15:38:09 EDT 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        65 |       147 |       230 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
