[GRASS-QA] GRASS QA: neteler |local_proto.h | no clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Mon May 9 07:55:46 EDT 2011
Hello neteler,
here's a report on your recent grass-SVN change for the revision : 46211
ANALYSIS
your changes to files/class/methods/functions :
File :/raster/r.fuzzy/local_proto.h
The system don't find class, method and function
in this file during analysis!
____________________________________________
Threshold grass key metrics values at Mon May 09 07:55:42 EDT 2011 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 21 | 33 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 64 | 145 | 226 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
