[GRASS-QA] GRASS QA: neteler |local_proto.h local_proto.h | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Mon May 9 08:03:53 EDT 2011
Hello neteler,
here's a report on your recent grass-SVN change for the revision : 46213
ANALYSIS
your changes to files/class/methods/functions :
          File :/grass7/raster/r.fuzzy/r.fuzzy.set/local_proto.h
The system don't find class, method and function
 in this file during analysis!
          File :/grass7/raster/r.fuzzy/r.fuzzy.system/local_proto.h
____________________________________________
Threshold grass key metrics values at Mon May 09 08:03:49 EDT 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        64 |       145 |       226 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
