[GRASS-QA] GRASS QA: neteler |main.c main.c local_proto.h
local_proto.h | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Mon May 9 09:26:31 EDT 2011
Hello neteler,
here's a report on your recent grass-SVN change for the revision : 46219
ANALYSIS
your changes to files/class/methods/functions :
File :/raster/r.pi/r.pi.import/main.c
The system don't find class, method and function
in this file during analysis!
File :/raster/r.pi/r.pi.export/main.c
Class
statmethod(Begins at: 10, Ends at:16)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Clone analysis:
This file does not contain cloned functions
File :/raster/r.pi/r.pi.import/local_proto.h
File :/raster/r.pi/r.pi.export/local_proto.h
____________________________________________
Threshold grass key metrics values at Mon May 09 09:26:27 EDT 2011 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 21 | 33 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 64 | 145 | 226 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
