[GRASS-QA] GRASS QA: mmetz |export_band.c | 1 clones | 1 monsters |2 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue May 17 11:00:05 EDT 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 46324
ANALYSIS
your changes to files/class/methods/functions :
          File :/raster/r.out.gdal/export_band.c
          Function
exact_range_check(Begins at: 461, Ends at:558)
              |          New Metrics           |Old Metrics|
Complexity:   |      21 |    ** | BABY-MONSTER |        21 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      49 |    ** | BABY-MONSTER |        49 |
LOC:          |      98 |     * |      WARNING |        98 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
export_band(Begins at: 210, Ends at:459)
Complexity:   |      31 |    ** | BABY-MONSTER |        31 |
ParamNBR:     |      11 |   *** |      MONSTER |        11 |
CalledNBR:    |      54 |    ** | BABY-MONSTER |        54 |
LOC:          |     250 |   *** |      MONSTER |       250 |
Conclusion:   | this function is a       MONSTER           |
exact_checks(Begins at: 32, Ends at:204)
Complexity:   |      28 |    ** | BABY-MONSTER |        28 |
ParamNBR:     |       8 |    ** | BABY-MONSTER |         8 |
CalledNBR:    |      27 |     * |      WARNING |        27 |
LOC:          |     173 |    ** | BABY-MONSTER |       173 |
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/raster/r.out.gdal/export_band.c clones of exact_range_check are:
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.out.gdal/export_band.c  exact_range_check
____________________________________________
Threshold grass key metrics values at Tue May 17 10:59:58 EDT 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        64 |       145 |       226 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
