[GRASS-QA] GRASS QA: mmetz |Gs3.c | 5 clones | 0 monsters |6 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Sun May 22 13:27:19 EDT 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 46347
ANALYSIS
your changes to files/class/methods/functions :
          File :/lib/ogsf/Gs3.c
          Function
Gs_loadmap_as_short(Begins at: 313, Ends at:390)
              |          New Metrics           |Old Metrics|
Complexity:   |       8 |       |           OK |         8 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      78 |     * |      WARNING |        78 |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
Gs_loadmap_as_int(Begins at: 179, Ends at:220)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |      14 |       |           OK |        14 |
LOC:          |      42 |       |           OK |        42 |
 at least 1 values are close to an outlier please consider revising code!
Gs_loadmap_as_bitmap(Begins at: 518, Ends at:563)
Complexity:   |       6 |       |           OK |         6 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      16 |       |           OK |        16 |
LOC:          |      46 |       |           OK |        46 |
Gs_loadmap_as_char(Begins at: 418, Ends at:497)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |      18 |     * |      WARNING |        18 |
LOC:          |      80 |     * |      WARNING |        80 |
 at least 4 values are close to an outlier please consider revising code!
Gs_get_cat_label(Begins at: 777, Ends at:840)
Complexity:   |       7 |       |           OK |         7 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      25 |     * |      WARNING |        25 |
LOC:          |      64 |     * |      WARNING |        64 |
Gs_loadmap_as_float(Begins at: 115, Ends at:157)
CalledNBR:    |      15 |       |           OK |        15 |
LOC:          |      43 |       |           OK |        43 |
Clone analysis:
This file has 5 potentially cloned functions:
  Gs_loadmap_as_int  Gs_loadmap_as_bitmap  Gs_loadmap_as_char  Gs_loadmap_as_float
In /data/project-manager/grass/grassSVN/grass/trunk/lib/ogsf/Gs3.c clones of Gs_loadmap_as_short are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/ogsf/Gs3.c  Gs_loadmap_as_short
In /data/project-manager/grass/grassSVN/grass/trunk/lib/ogsf/Gs3.c clones of Gs_loadmap_as_int are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/ogsf/Gs3.c  Gs_loadmap_as_int
In /data/project-manager/grass/grassSVN/grass/trunk/lib/ogsf/Gs3.c clones of Gs_loadmap_as_bitmap are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/ogsf/Gs3.c  Gs_loadmap_as_bitmap
In /data/project-manager/grass/grassSVN/grass/trunk/lib/ogsf/Gs3.c clones of Gs_loadmap_as_char are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/ogsf/Gs3.c  Gs_loadmap_as_char
In /data/project-manager/grass/grassSVN/grass/trunk/lib/ogsf/Gs3.c clones of Gs_loadmap_as_float are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/ogsf/Gs3.c  Gs_loadmap_as_float
____________________________________________
Threshold grass key metrics values at Sun May 22 13:27:08 EDT 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        64 |       146 |       228 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
