[STATSGRASS] raster cross-stats
Roger Bivand Roger.Bivand at nhh.no
Mon Dec 31 05:29:57 EST 2001
Markus!
On Sun, 30 Dec 2001, Markus Neteler wrote:
> In fact I want to run
>  R CMD BATCH
> I have a small text file (Rbatchfile):
> library(GRASS)
> G <- gmeta()
> mapname <- "$1"
> map <- rast.get(G, mapname)
> map.frame <- data.frame(east(G), north(G), map$mapname)
> summary(map.frame)
> Then I run the batch job:
> R BATCH Rbatchfile aspect
> cat aspect   # for some reason stored into this filename
> Running in /usr/local/share/grassdata/spearfish/user1
> > G <- gmeta()
> > mapname <- "$1"
> Error in rast.get(G, mapname) : raster map: $1 not found
> Execution halted
> When hard-coding the map name in the text file, everything runs
> well. But I don't get it flexible.
The short answer is Sys.getenv().
Here I started R, did:
> data(cars)
> write.table(cars, "cars.txt")
> q()
to generate a test file. The batch file then refers to environment
variables which I assigned the file names to be used:
$ cat Rbatchfile.in
cars <- read.table(Sys.getenv("R_TABLE_IN"))
sink(Sys.getenv("THIS_R_OUT"))
cor(cars$dist, cars$speed)
summary(lm(dist ~ speed, cars))
sink()
$ echo $R_TABLE_IN
cars.txt
$ echo $THIS_R_OUT
R.out.1
So the batch file found them, and wrote the results to the output file.
$ R CMD BATCH Rbatchfile.in
$ cat R.out.1
[1] 0.8068949
Call:
lm(formula = dist ~ speed, data = cars)
Residuals:
    Min      1Q  Median      3Q     Max
-29.069  -9.525  -2.272   9.215  43.201
Coefficients:
            Estimate Std. Error t value Pr(>|t|)
(Intercept) -17.5791     6.7584  -2.601   0.0123 *
speed         3.9324     0.4155   9.464 1.49e-12 ***
Signif. codes:  0 `***' 0.001 `**' 0.01 `*' 0.05 `.' 0.1 ` ' 1
Residual standard error: 15.38 on 48 degrees of freedom
Multiple R-Squared: 0.6511,     Adjusted R-squared: 0.6438
F-statistic: 89.57 on 1 and 48 DF,  p-value: 1.49e-12
Even works in a loop in a shell script, replacing the strings needed in R.
For your case that would be:
library(GRASS)
G <- gmeta()
mapname <- Sys.getenv("THIS_RASTER")
sink(Sys.getenv("THIS_OUTFILE"))
summary(map.frame)
sink()
for shell variables $THIS_RASTER and $THIS_OUTFILE. I don't think it will
fly for numbered arguments to the R CMD BATCH script.
Very best wishes for the New Year to you and others on this list!
Roger
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand at nhh.no
and: Department of Geography and Regional Development, University of
Gdansk, al. Mar. J. Pilsudskiego 46, PL-81 378 Gdynia, Poland.
More information about the grass-stats mailing list
