[STATSGRASS] RPgSQL_1.0-0.tar.gz
Seppo Kaitala seppo.kaitala at fimr.fi
Tue Jul 24 09:08:23 EDT 2001
Hello list
I have installed GRASS 5.0.0pre1 and  R 1.3.0 , GRASS_0.1-7 and
RPgSQL_1.0-0.
When I try to run the spearefish demo (4.1 ) in the paper
Open Source geocomputation: using the R data analysis language
integrated with GRASS GIS and
PostgreSQL data base systems ( Bivand and Neteller 2000)
I got stuck with the command
 db.connect("localhost", "5432","soils_ph_db")
Error in db.connect("localhost", "5432", "soils_ph_db") :
	Connection failed
When I look the databases with command (under grass )
 g.select.pg -l
The following databases are in the Unix catalogue:
template1
water
water2
water3
soils_ph_db
test
So the database seems to be there.
Would somebody please help me how I could get further and what the
problem might be
(bug in RPgSQL_1.0-0 ???).
Best regards
Seppo Kaitala
Merentutkimuslaitos, PL 33 (Lyypekinkuja 3), 00931 Helsinki
Institute of Marine Research, PO Box 33, FIN-00931 Helsinki, Finland
tel. +358-9-613941    fax +358-9-6857 638
More information about the grass-stats mailing list
