[STATSGRASS] grass, gstat, and 3d maps
    Javier
    andresjavier.garcia at wanadoo.es
    Wed Apr 24 04:53:06 EDT 2002
Hi Edzer;
I've tried to save you a little of work. I send you the sites file, and in
the file "paraEdzer.txt", there are all the posibilities I've tried in the
command file, followed by the corresponding answers.
Javier
----- Original Message -----
To: Javier <andresjavier.garcia at wanadoo.es>
Cc: <statsgrass at grass.itc.it>
Sent: Tuesday, April 23, 2002 9:24 AM
Subject: Re: [STATSGRASS] grass, gstat, and 3d maps
> I wrote grass support in gstat such that also the z-dimension was
> used; if the z-dimension is in column 3 of the site list, you should use:
> data(something): 'sites', z=3;
> i.e., x- and y-coordinates are assumed to be in column 1 and 2.
> It is not unlikely that you are the first one to test this feature, so
> please bear with us. Could you send me the offending command file, the
> sites data (or part of it), and the output gstat gives you?
> Edzer
If I don't specify any coordinate or data, the first set of data is read, but only 2d are considered:	data(traz1):"trazas1";
gstat: Linux version 2.3.6 (28 January 2002)
Copyright (C) 1992, 2001 Edzer J. Pebesma
name|trazas1
desc|s.in.ascii sites=trazas1
GRASS site list trazas1: 0 cat, 3 dim, 0 str, 2 dbl.
Warning: gstat/grass: specify z coordinate if you want to use it
data(traz1): gstat/grass: 547 sites read successfully.
         trazas1     (GRASS site list)
attribute:             col[1]     [x:] x_1        : [    686000,    711000]
n:                        547     [y:] y_2        : [ 4.185e+06, 4.205e+06]
sample mean:           1.4757     sample std.:         0.621017
[starting interactive mode]
Just the same if I specify:	data(traz1):"trazas1",v=1;
name|trazas1
press return to continue...
In this way, I can specify the second set of data, but still are considered 2d:	data(traz1):"trazas1",v=2;
name|trazas1
attribute:             col[2]     [x:] x_1        : [    686000,    711000]
sample mean:          67.3692     sample std.:          36.3099
If I try to specify the first set of data in this way:	data(traz1):"trazas1",v=4;
name|trazas1
Warning: gstat/grass doubles in site list are ignored, check data v field!
gstat: value not allowed for: data v field not found in sites list
If I just specify the z column (as z=3), at last z column is read but now no set of data is established: data(traz1):"trazas1",z=3;
name|trazas1
data(traz1): using coordinate column 3 as z-coordinategstat/grass: 547 sites read successfully.
attribute:             col[1]
n:                        547
no v attribute set for data(traz1)
gstat: variable not set: trazas1.cmd
Just the same if I specify:	data(traz1):"trazas1",z=3,v=1;
name|trazas1
attribute:             col[1]
n:                        547
A different message when I try:	data(traz1):"trazas1",z=3,v=4;
name|trazas1
I have also tried:	data(traz1):"trazas1",x=1,y=2,z=3,v=4;
name|trazas1
And:	data(traz1):"trazas1",x=1,y=2,z=3,v=5;
name|trazas1
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-stats/attachments/20020424/b7aaf13b/trazas1.obj
More information about the grass-stats
