[STATSGRASS] gstat and grass raster null values
Agustin Lobo
alobo at ija.csic.es
Fri Apr 4 11:26:21 EST 2003
Apparentely, gstat does not
handle grass null values. At least,
I've found problems with gstat
if null values are not masked out.
Therefore,
it's important to set a proper mask.
Something like:
r.mapcalc "MASK = if(isnull(raster),null(),1)"
will create a MASK for null values
or inlude them in the active mask.
Also, thanks to Edzer, Im using
the following line command style for gstat
in grass scripts:
gstat -e semivariogram -c $cut -i $wid dum > $nout
Hope this helps (and that I'm not wrong).
Agus
Dr. Agustin Lobo
Instituto de Ciencias de la Tierra (CSIC)
Lluis Sole Sabaris s/n
08028 Barcelona SPAIN
tel 34 93409 5410
fax 34 93411 0012
More information about the grass-stats
