[STATSGRASS] Re: [R-sig-Geo] numeric(0) ?????
Ole F. Christensen
olefc at daimi.au.dk
Tue Dec 2 06:04:06 EST 2003
Dear Massimiliano
How about
for (i in 1:20){
if(any(T$pluto==i)) T$pippo[T$pluto==i]
Depending on what you want to do with these subsets of the data.frame,
you might want to consider using
``tapply'' or ``by'' [se the help-files for these functions] instead of
the for loop.
For example :
tapply(T$pluto,T$pippo, sum)
Cheers
Ole
Massimiliano Cannata wrote:
>hello,
>I have a little problem with my script:
>I select a subset from a data frame
>for (i in 1:20){
>T$pippo[T$pluto==i]
>but sometime it is void because T$pluto==5 does not exists, the R answer is:
>T$pippo[T$pluto==5]
>>numeric(0)
>how to exclude this null subset?
>and what is numeric(0), similar to NA?
>I try an if statement, but how to write if T$pippo[T$pluto==i] is numeric(0)???
>Thanks a lot.
>Maxi
>Ing. Massimiliano Cannata
>Istituto di Scienze della Terra - SUPSI
>C.P. 72 - CH-6952 Canobbio (Ticino, Switzerland)
>Tel +41 91 /935 12 25 - Fax +41 91 /935 12 09
>eMail: massimiliano.cannata at supsi.ch
>Internet: http://www.ist.supsi.ch
> [[alternative HTML version deleted]]
>_______________________________________________
>R-sig-Geo mailing list
>R-sig-Geo at stat.math.ethz.ch
>https://www.stat.math.ethz.ch/mailman/listinfo/r-sig-geo
Ole F. Christensen
Center for Bioinformatik
Datalogisk Institut
Aarhus Universitet
Ny Munkegade, Bygning 540
8000 Aarhus C
Denmark
More information about the grass-stats
