[STATSGRASS] writing grass format from R
Edzer J. Pebesma e.pebesma at geog.uu.nl
Tue Jun 10 07:26:39 EDT 2003
Christian,
gstat nowadays has two reincarnations: (i) as stand-alone program,
in which case it can read and write grass data and maps; (ii) as an R
package (or S-PLUS library), in which case it operates directly in
the R environment. It cannot do both at the same time. However,
there is a R-GRASS interface. AFAIK it does not write graph results to
GRASS, but it can write R data back to grass. GRASS can make
the graphs, I'd say.
I'm not familiar to Mapserver.
Edzer
Christian Blumer wrote:
> Dear list,
>  I would like to know if there is a way to write a R graph results
> into Grass image format?
> Or should I use Gstat?
> The idea behind is to produce geostatistical modeled images that are
> then made accessible through internet through Mapserver.
> Christian
More information about the grass-stats mailing list
