[STATSGRASS] ROracle problm
Massimiliano Cannata
massimiliano.cannata at supsi.ch
Thu Feb 26 05:24:19 EST 2004
Hi, i have a problem running ROracle library.
I have set all the $ORACLE_HOME and $PATH variable, my Oracle installation goes fine but when i try to lunch:
library("ROracle")
it gives me an error message:
unable to load shared library /usr/lib/R/library/ROracle/libs/ROracle.so":
/usr/lib/R/library/ROracle/libs/ROracle.so: undefined symbol: sqlca
Error in library("ROracle") : .First.lib failed
Any idea about what to do?
I sow a couple of messages with this error but the solution suggested doesn't seems to work for me!
here my packages:
- ROracle_0.5-3
- DBI_0.1-7
- RedHat9
- Oracle9iR2
Thanks you all.
Maxi
Ing. Massimiliano Cannata
Istituto di Scienze della Terra - SUPSI
C.P. 72 - CH-6952 Canobbio (Ticino, Switzerland)
Tel +41 91 /935 12 25 - Fax +41 91 /935 12 09
eMail: massimiliano.cannata at supsi.ch
Internet: http://www.ist.supsi.ch
note: change my e-mail reference to massimiliano.cannata at supsi.ch
because the old one will be deleted soon.
URL: http://lists.osgeo.org/pipermail/grass-stats/attachments/20040226/95cef4eb/attachment.html
More information about the grass-stats
