[STATSGRASS] Using GRASS/R interface with an xy location & reverse(G) error
Steven T.Stoddard
sstoddar at life.uiuc.edu
Tue Feb 8 12:13:41 EST 2005
Ok. The work-around I can grow accustomed to, or I might fall back on
GRASS5.4 if that works.
I wonder if another problem that cropped up is somehow related to the
first. Using interp=TRUE I managed to import a raster map to R. But
when trying to plot it, I get the following:
> plot(G,tt$rb1)
Error in reverse(G) : cannot allocate vector of length 1086556160
Thanks for the help,
Steve
Steven T. Stoddard
Program in Ecology, Evolution and Conservation Biology
University of Illinois at Urbana-Champaign
(217) 333-2235
302 Shelford Vivarium
606 E. Healy Ave
Champaign, IL 61820
http://www.life.uiuc.edu/~sstoddar
On Feb 8, 2005, at 10:58 AM, Roger Bivand wrote:
> On Tue, 8 Feb 2005, Steven T.Stoddard wrote:
>> I am using GRASS 5.7 and R 2.0 for OS X. I have a simple xy location
>> I
>> am doing some theoretical work with and would like to import maps into
>> R using the interface in order to do analyses. Yet when I attempt to
>> do this, I get the following error:
>>> G<-gmeta()
>> Error in gmeta() : region for current mapset is invalid
>> line 11: <top: 100>
>> run "g.region"
>> I traced the problem to the compiled C program that is called from the
>> gmeta R function (i.e. > .C("gmeta") gives me the same error). I
>> haven't been able to locate the source code on my volume.
>> If I use gmeta(interp = TRUE) there is no problem, until I want to
>> actually try and import data from my locations.
> The current fix for 5.7 and 6.0.0beta is to use interp=TRUE. The cause
> of
> the problem seems to be the use of the 3D WINDOW, which the older code
> in
> the R-GRASS interface doesn't yet honour. I'm not at all sure what will
> happen if your x,y locations are sites; the interface knows about
> old-style sites, not vector sites. You may be obliged to use
> system("") to
> issue GRASS 5.7 commands to write out an ASCII file to read into R with
> read.table().
> Roger
>> Any help is appreciated.
>> Steve
>> Steven T. Stoddard
>> (217) 333-2235
>> 606 E. Healy Ave
>> Champaign, IL 61820
> Roger Bivand
> Economic Geography Section, Department of Economics, Norwegian School
> of
> Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
> Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
> e-mail: Roger.Bivand at nhh.no
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-stats/attachments/20050208/9415d902/attachment.bin
More information about the grass-stats
