[STATSGRASS] GSTAT 2.4.5 compile problem with GRASS 6
S. Koukoulas
skouk at geo.aegean.gr
Mon Jun 20 11:04:41 EDT 2005
I get an error when I am trying to compile GSTAT 2.4.5 with the grass
option. Any solutions?
Many thanks in advance
Sotiris
gcc -o gstat block.o data.o direct.o fig.o fit.o getest.o gls.o glvars.o
gstat.o lex.o lm.o map2fig.o map2gd.o mapio.o maputils.o msim.o nsear
ch.o ossfim.o palet.o parse.o plot.o polygon.o pqueue.o predict.o
random.o read.o reml.o report.o sample.o select.o sem.o sem_main.o sim.o sta
t.o ui.o userio.o utils.o vario.o vario_fn.o vario_io.o writecmd.o
xvalid.o -L../lib -lmeschach -lnetcdf -lncurses -lgd -lpng -lz -lgdal -L
/usr/local/grass-6.0.0beta2/lib -lgrass_gis -lgrass_datetime
-lgrass_sites -lz -lm
/usr/lib/gcc-lib/i586-suse-linux/3.3.4/../../../../i586-suse-linux/bin/ld:
warning: libgrass_dbmiclient.so, needed by /usr/local/grass-6.0.0be
ta2/lib/libgrass_sites.so, not found (try using -rpath or -rpath-link)
warning: libgrass_dbmibase.so, needed by /usr/local/grass-6.0.0beta
warning: libgrass_vect.so, needed by /usr/local/grass-6.0.0beta2/li
warning: libgrass_dig2.so, needed by /usr/local/grass-6.0.0beta2/li
warning: libgrass_dgl.so, needed by /usr/local/grass-6.0.0beta2/lib
warning: libgrass_rtree.so, needed by /usr/local/grass-6.0.0beta2/l
warning: libgrass_linkm.so, needed by /usr/local/grass-6.0.0beta2/l
/usr/local/grass-6.0.0beta2/lib/libgrass_sites.so: undefined reference
to `Vect_reset_line'
to `db_get_num_rows'
to `Vect_set_open_level'
to `Vect_get_field'
to `Vect_is_3d'
to `Vect_set_map_name'
to `db_init_string'
to `db_get_column_sqltype'
to `Vect_open_old'
to `db_open_select_cursor'
to `Vect_new_cats_struct'
to `Vect_get_name'
to `db_start_driver_open_database'
to `Vect_get_date'
to `Vect_write_line'
to `Vect_close'
to `db_get_value_double'
to `db_sqltype_to_Ctype'
to `db_close_database_shutdown_driver'
to `db_get_value_string'
to `db_get_column_value'
to `db_append_string'
to `Vect_cat_get'
to `Vect_read_next_line'
to `db_get_column_name'
to `db_get_value_int'
to `Vect_append_point'
to `Vect_set_date'
to `Vect_set_comment'
to `db_get_table_column'
to `Vect_cat_set'
to `db_fetch'
to `db_get_table_number_of_columns'
to `db_set_string'
to `db_get_cursor_table'
to `Vect_reset_cats'
to `Vect_get_comment'
to `Vect_new_line_struct'
to `Vect_build'
to `Vect_open_new'
collect2: ld returned 1 exit status
make[1]: *** [gstat] Error 1
make[1]: Leaving directory `/local/phome/Installs/gstat-2.4.5/src'
make: *** [src/gstat] Error 2
More information about the grass-stats
