[STATSGRASS] GSTAT 2.4.5 compile problem with GRASS 6
S. Koukoulas skouk at geo.aegean.gr
Mon Jun 20 12:38:24 EDT 2005
Thomas et al,
Since my first email I thought that I have actually sorted the problem
by using the -grass6 option instead of -grass.
The "make" finished without apparent errors, but now I get the following
message when I run
gstat -v
sotiris at linux:~>gstat: error while loading shared libraries:
libgrass_sites.so: cannot open shared object file: No such file or directory
It is still looking for grass5 libraries where it should not...  I don't
have grass5 installed in my system...
Any help would be appreciated
Sotiris
P.S: gstat 2.4.4 did not work either. When I use the -grass options it
can't find the libs, it ignores --grass6 option
Thomas Adams wrote:
> Sotiris,
> It looks like the build process does not know where the GRASS libs are
> located starting just a few lines down:
> warning: libgrass_dbmiclient.so, needed by
> /usr/local/grass-6.0.0beta2/lib/libgrass_sites.so, not found
> warning: libgrass_vect.so, needed by
> etc.
> Tom
> S. Koukoulas wrote:
>> I get an error when I am trying to compile GSTAT 2.4.5 with the grass
>> option. Any solutions?
>> Many thanks in advance
>> Sotiris
>> gcc -o gstat block.o data.o direct.o fig.o fit.o getest.o gls.o
>> glvars.o gstat.o lex.o lm.o map2fig.o map2gd.o mapio.o maputils.o
>> msim.o nsear
>> ch.o ossfim.o palet.o parse.o plot.o polygon.o pqueue.o predict.o
>> random.o read.o reml.o report.o sample.o select.o sem.o sem_main.o
>> sim.o sta
>> t.o ui.o userio.o utils.o vario.o vario_fn.o vario_io.o writecmd.o
>> xvalid.o  -L../lib  -lmeschach -lnetcdf  -lncurses -lgd -lpng -lz
>> -lgdal -L
>> /usr/local/grass-6.0.0beta2/lib -lgrass_gis -lgrass_datetime
>> -lgrass_sites -lz -lm
>> /usr/lib/gcc-lib/i586-suse-linux/3.3.4/../../../../i586-suse-linux/bin/ld:
>> warning: libgrass_dbmiclient.so, needed by /usr/local/grass-6.0.0be
>> ta2/lib/libgrass_sites.so, not found (try using -rpath or -rpath-link)
>> warning: libgrass_dbmibase.so, needed by /usr/local/grass-6.0.0beta
>> warning: libgrass_vect.so, needed by /usr/local/grass-6.0.0beta2/li
>> warning: libgrass_dig2.so, needed by /usr/local/grass-6.0.0beta2/li
>> warning: libgrass_dgl.so, needed by /usr/local/grass-6.0.0beta2/lib
>> warning: libgrass_rtree.so, needed by /usr/local/grass-6.0.0beta2/l
>> warning: libgrass_linkm.so, needed by /usr/local/grass-6.0.0beta2/l
>> /usr/local/grass-6.0.0beta2/lib/libgrass_sites.so: undefined
>> reference to `Vect_reset_line'
>> reference to `db_get_num_rows'
>> reference to `Vect_set_open_level'
>> reference to `Vect_get_field'
>> reference to `Vect_is_3d'
>> reference to `Vect_set_map_name'
>> reference to `db_init_string'
>> reference to `db_get_column_sqltype'
>> reference to `Vect_open_old'
>> reference to `db_open_select_cursor'
>> reference to `Vect_new_cats_struct'
>> reference to `Vect_get_name'
>> reference to `db_start_driver_open_database'
>> reference to `Vect_get_date'
>> reference to `Vect_write_line'
>> reference to `Vect_close'
>> reference to `db_get_value_double'
>> reference to `db_sqltype_to_Ctype'
>> reference to `db_close_database_shutdown_driver'
>> reference to `db_get_value_string'
>> reference to `db_get_column_value'
>> reference to `db_append_string'
>> reference to `Vect_cat_get'
>> reference to `Vect_read_next_line'
>> reference to `db_get_column_name'
>> reference to `db_get_value_int'
>> reference to `Vect_append_point'
>> reference to `Vect_set_date'
>> reference to `Vect_set_comment'
>> reference to `db_get_table_column'
>> reference to `Vect_cat_set'
>> reference to `db_fetch'
>> reference to `db_get_table_number_of_columns'
>> reference to `db_set_string'
>> reference to `db_get_cursor_table'
>> reference to `Vect_reset_cats'
>> reference to `Vect_get_comment'
>> reference to `Vect_new_line_struct'
>> reference to `Vect_build'
>> reference to `Vect_open_new'
>> collect2: ld returned 1 exit status
>> make[1]: *** [gstat] Error 1
>> make[1]: Leaving directory `/local/phome/Installs/gstat-2.4.5/src'
>> make: *** [src/gstat] Error 2
>> statsgrass mailing list
>> statsgrass at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/statsgrass
More information about the grass-stats mailing list
