[STATSGRASS] making R and grass(6.1) play well together.
Edzer J. Pebesma
e.pebesma at geog.uu.nl
Wed Jun 29 11:39:30 EDT 2005
Tom Colson wrote:
>Thanks for the quick reply.
>I did install spgrass6 and all its dependencies and have managed to
>reproduce this:
>>library(spgrass6)
>>G <- gmeta6()
>>dem <- readFLOAT6sp("ncfpm_2694")
>Specifically, though, I am seeking how to import the raster DEM into
>some sort of format that the stats library will recognize so I can plot
>the ecdf cruves......ie..
>library(stats)
I think library stats is attached by default, so can be omitted.
>plot(ecdf(dem))
>plot(ecdf(dem), verticals=T, do.points=F)
Please try:
dem.df = as.data.frame(dem)
plot(ecdf(dem.df[["ncfpm_2694"]]))
Edzer
>On Wed, 2005-06-29 at 17:30 +0200, Edzer J. Pebesma wrote:
>>Tom, there has been quite a bit of development in this area;
>>first we have made an R package (sp) which has classes and
>>methods for dealing with spatial points, lines, polygons and grid
>>objects in R, and then Roger rewrote the grass R package to
>>work with these data. You can read about it in the latest
>>grass news, and you can see (more) examples on
>>http://r-spatial.sourceforge.net/ , follow the link "sp and other
>>packages" which has examples on spgrass6.
>>Best regards,
>>Edzer
>>Tom Colson wrote:
>>>I managed to get R compiled and all the packages talking to grass as it
>>>should, and all the "demos" seem to work. There is a neat tutorial on
>>>working with DEM (grass raster) in R
>>>http://grass.itc.it/statsgrass/learning_r2.html#Working_with_elevation
>>>Tutorial works great with the sample data provided...yet I can't figure
>>>out how to get "current" raster dems in my mapset/location into a format
>>>that is acceptable to R...re: the tutorial syntax. Been looking through
>>>all the man pages, but there doesn't seem to be any documentation on
>>>raster import that would allow one to go through that tutorial using
>>>one's own data....
>_______________________________________________
>statsgrass mailing list
>statsgrass at grass.itc.it
>http://grass.itc.it/mailman/listinfo/statsgrass
More information about the grass-stats
