[STATSGRASS] GSTAT 2.4.3 compile problem with GRASS 5.4
Roger Bivand
Roger.Bivand at nhh.no
Wed Mar 16 04:22:31 EST 2005
On Wed, 16 Mar 2005, Edzer J. Pebesma wrote:
> Roger Bivand wrote:
> >On Tue, 15 Mar 2005, Edzer J. Pebesma wrote:
> >>Roger Bivand wrote:
> >>>On Tue, 15 Mar 2005, Thomas Adams wrote:
> >>>>I am having GSTAT 2.4.3 compile problems with GRASS 5.4. When
> >>>>configuring gstat for compilation I use:
> >>>>./configure --with-grass=/awips/rep/lx/local_apps/grass-build
> >>>>The GRASS 5.4 lib & include directories are located in
> >>>>/awips/rep/lx/local_apps/grass-build, but I notice when gstat is being
> >>>>configured for compilation, I get:
> >>>>checking for G_gisinit in -lgrass_gis... no
> >>>>checking for G_gisinit in -lgis... no
> >>>Edzer: is this related to 5.4.0 going just shared? That only the *.so are
> >>>in build/dist*/lib? On grass5, Glynn asked on Sunday:
> >>>"I think that the point is that binary distributions should always
> >>>include the libraries regardless of whether they are shared or static.
> >>>IIRC, we currently only include the libraries if they are shared
> >>>libraries.
> >>>From a packaging (RPM etc) perspective, static libraries would
> >>>normally go into a separate -devel package, along with the headers,
> >>>while shared libraries would go into the main package."
> >>>The configure seems to fail because it is looking for libgis.a or
> >>>libgrass_gis.a at:
> >>> AC_CHECK_LIB(grass_gis, G_gisinit, GISLIB="-lgrass_gis -lgrass_datetime",
> >>> AC_CHECK_LIB(gis, G_gisinit, GISLIB="-lgis -ldatetime"))
> >>>isn't it? Should it see a *.so as an *.a, they are different animals,
> >>>aren't they?
> >>No. They're different, but the .a are not required. gstat 2.4.4
> >>links to grass-6.0.0beta1, which contains only .so in the lib dir;
> >>I tried the 2.4.3 (targeted at grass 5.x) and the configure
> >>worked on the grass6 machine, it finds the .so libraries. Then it
> >>doesn't compile, for obvious reasons.
> >>Thomas, could you double-check the directory names?
> >It could be that grass-build is actually grass-build/dist.*
> >I've tried without success with 2.4.3 on 5.4.0 on my machine, both going
> >for the grass-build/dist* and the install directory grass54/ which has lib
> >in it. I've got a working 5.4.0 (I think).
> Roger, I'm sorry, you were right, but it can be solved easily.
> The issue is that dynamic libraries are only linked against
> automatically if they are in a "trusted"
> directory, which are on my machine listed in /etc/ld.so.conf
> (run ldconfig after you modify it; read man ldconfig).
> So if you want to run gstat with grass support any way,
> you'd have to add the /usr/local/grassxxx/lib directory
> there, and run ldconfig.
> If you _only_ want to run gstat within grass sessions (which
> makes sense, because only then it should know where to
> look for data!) you should run
> ./configure --with-grass=/path/to/grass
> within the grass shell, because grass sets the
> environment variable to your active grass version lib dir:
> LD_LIBRARY_PATH=/usr/local/grass-6.0.0beta1/lib
> which has the same effect, but only for the session in
> which this env var is set.
Yes, I can confirm that this works:
[rsb at localhost gstat-2.4.3]$ ~/topics/grass54/bin/grass54
GRASS:~/tmp/gstat-2.4.3 > ./configure --with-grass=/home/rsb/topics/grass54/grass54
checking for G_gisinit in -lgrass_gis... yes
but this is better:
GRASS:~/tmp/gstat-2.4.3 > ./configure --with-grass=$GISBASE
from inside GRASS.
But it will bite - won't it - if gstat is compiled and linked against 5.4
but started in 6.0? The version check function is only in 6.0, so
otherwise only g.version is available at the shell level.
$ ls -l *gis*
-rwxrwxr-x 1 rsb rsb 815955 Dec 27 16:21 libgrass_gis.so*
$ pwd
/home/rsb/topics/grass54/grass54/lib
$ ls -l *gis*
-rwxrwxr-x 1 rsb rsb 838602 Mar 10 14:09
libgrass_gis.6.0.0.so*
lrwxrwxrwx 1 rsb rsb 21 Mar 10 14:20 libgrass_gis.so -> libgrass_gis.6.0.0.so*
$ pwd /home/rsb/topics/grass600/grass-6.0.0/lib
I agree with Glynn, GRASS should ship with *.a too, and for binary
installers, there should be *-devel packages.
Roger
> In that case, when gstat is ran outside a grass session
> you'll get something like
> gstat: error while loading shared libraries: libgrass_gis.so: cannot
> open shared object file: No such file or directory
> because gstat (actually the runtime linker) doesn't know
> where to find the .so files. I figure you get this too when
> running grass binaries outside a grass shell.
> Best regards,
> Edzer
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats
