[STATSGRASS] Re: Connecting to databases on Windows using R
    Markus Neteler
    neteler at itc.it
    Thu Mar 17 15:30:22 EST 2005
Hi
(for me) it's strange that Rdbi doesn't appear on CRAN but
I was already notified once not to discuss Rdbi questions on
the R Mailing lists... (so better to ask here :-)
Anyway, I have compiled some usage instructions here:
 http://grass.itc.it/statsgrass/r_and_dbms.html
which should be more or less still valid.
Maybe a bit helpful, also comparing speed of Rdbi and RODBC.
However, it doesn't cover MS-Win installation...
Best
 Markus
On Thu, Mar 17, 2005 at 11:33:02AM -0700, Craig Aumann wrote:
> See Teague's question below.  As a linux person, I don't know the answer
> to this so am forward this message to the list.
> Having looked also at  http://www.bioconductor.org/ - which links off of
> the main R web page, I see a Windows version of Rdbi (click "What is
> Bioconductor"  and scroll down till you find the heading: "Database
> Interaction").  I'm seeing a RDBI for Windows, but no windows version of
> RdbiPgsql which is a problem!
> Have you tried sending a message to the R-Help list about this - how do
> windows users access PGSQL databases from R?  (R website -> mailing
> lists.)
> On the CRAN site, just searching databases, I saw the following:
> DBI, RMySQL, RODBC, ROracle. Not sure if windows versions exist for any
> of these.
> Also have a look at the links in
> http://cran.r-project.org/doc/manuals/R-data.html .
> Afraid that's all I know about attaching to Databases on Windows - which
> ain't much I'm afraid.
> Cheers!
> Craig
> On Thu, 2005-03-17 at 10:40, Teague O'Mara wrote:
> > Hi Craig.  I came back across this email from awhile ago.  I'm attempting to
> > look at cluster of points in GRASS and have been using the script that Michael
> > Barton wrote, but I'd like to look at a few other things and it seems that using
> > R and my GRASS data will be much easier. I have been using R for basic
> > statistics, but am far from being fluent with it.  If you have a moment, can you
> > help me out with some R issues?  I'm using an XP machine with R 2.0.1.
> > I'm having a problem downloading and installing Rdbi and RdbiPgSQL.  I can't
> > find these two sets, or any SQL interface that will download from CRAN.  I was
> > able to download these directly from sourcforge (tar.gz format), but I'm not
> > sure what to do with them now.  Is it an issue with this version of R?
> > Thanks for any help you can offer.
> > Cheers--
> > Teague
> > Teague O'Mara
> > Department of Anthropology
> > Arizona State University
> > Box 872402
> > Tempe, AZ 85287-2402
> > 480.965.6213
> > Quoting Craig Aumann <caumann at ualberta.ca>:
> > > In glancing at your script, I wondered why you didn't just import the
> > > stuff into a statistical package like R and then use all the
> > > clustering
> > > routines it has.    See www.r-project.org
> > > ## Key commands in R are:
> > > ## Load the packages to access the database, in particular the PgSQL
> > > database
> > > require(Rdbi)
> > > require(RdbiPgSQL)
> > > ## Load some clustering routines
> > > require(cluster)
> > > require(mclust)
> > > ### Connect to the database and read in a points data set "jogis"
> > > ## and read in the dataset "wells_att".
> > > conn <- dbConnect(PgSQL(), dbname="jogis", user="caumann")
> > > wells <- dbReadTable(conn, "wells_att")
> > > dbDisconnect(conn)
> > > ## Now you can apply any clustering or kernel smoothing technique you
> > > want to the dataset.
> > > If this is of any help, let me know and I can provide more details.
> > > Cheers!
> > > Craig
> statsgrass mailing list
> statsgrass at grass.itc.it
> http://grass.itc.it/mailman/listinfo/statsgrass
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
More information about the grass-stats
