[STATSGRASS] CRS(): PROJ4 argument-value pairs must begin with +
rsadler at cyllene.uwa.edu.au rsadler at cyllene.uwa.edu.au
Wed Sep 28 01:50:55 EDT 2005
I have just installed grass6.0 on a new machine, and come up with a new
error (for me!).
 test5x<-readCELL6sp("test.product5")
Error in CRS(system("g.proj -j -f", intern = TRUE)) :
        PROJ4 argument-value pairs must begin with +: XY location
(unprojected)
It looks like the CRS function in readCELL6sp is not liking the projection
information (or lack thereof), hence can't provide a projection when
reading in ascii.grid format.  When I exclude P4<-CRS(...) and just use
CRS(as.char(NA)) my later functions that process the coverage bug out.
What do I do from here?
The raster coverage has worked on a previous machine using readCELL6sp.
The coverage does have nodata values amongst other integer category values
Regards
rohan sadler
system("g.proj -j")
XY location (unprojected)
r.info map=test.product5
 | Layer:    test.product5                  Date: Wed Sep 28 11:48:57 2005
 | Mapset:   rsadler                        Login of Creator: rsadler
 | DataBase: /home/rohan/simulations
 | Title:     ( test.product5 )
 |   Type of Map:  cell                Number of Categories: 393
 |   Data Type:    CELL
 |   Rows:         250
 |   Columns:      250
 |   Total Cells:  62500
 |        Projection: x,y (zone 0)
 |            N:          1    S:          0   Res: 0.004
 |            E:          1    W:          0   Res: 0.004
 |   Range of data:    min =  1 max = 393
 |   Data Source:
 |   Data Description:
 |    generated by r.mapcalc
 |   Comments:
 |    test51 * test52
Regards
Rohan
More information about the grass-stats mailing list
