[STATSGRASS] Re: [R-sig-Geo] file format error with R and GRASS61
Roger Bivand
Roger.Bivand at nhh.no
Thu Jan 19 16:06:49 EST 2006
On Thu, 19 Jan 2006, Kirk R. Wythers wrote:
> I am trying to figure out an GDAL error message about grass file not
> being a supported format. The message is:
> > gmeta6 <- gmeta6()
> > fname <- paste(gmeta6$GISDBASE, gmeta6$LOCATION_NAME,
> + "PERMANENT", "cellhd", "soils.ph",
> + sep="/")
> > soilsph_GDAL <- read.GDAL(fname)
> Error in .local(.Object, ...) :
> GDAL Error 4: `~/grassdata/spearfish60/PERMANENT/cellhd/
> soils.ph' not recognised as a supported file format.
If r.out.gdal works for you on that file, then we have a problem. However,
I think that your GRASS GDAL plugin is not present, so GDAL doesn't know
how to read GRASS rasters natively. What does
> getGDALDriverNames()
say within R after loading the rgdal package, or equivalently
$ gdalinfo --formats
from the shell prompt? If you see "GRASS" there, we have a problem, if
not, please make sure the GDAL GRASS plugin is installed and working (one
does this *after* installing GRASS.
Roger
> This is on grass61 and R 2.2.1 using the spearfish60 location
> Thanks in advance for any ideas
> R-sig-Geo mailing list
> R-sig-Geo at stat.math.ethz.ch
> https://stat.ethz.ch/mailman/listinfo/r-sig-geo
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats
