[STATSGRASS] Re: [R-sig-Geo] file format error with R and GRASS61
Markus Neteler
neteler at itc.it
Mon Jan 23 07:42:54 EST 2006
On Fri, Jan 20, 2006 at 01:13:30PM -0500, Scott Mitchell wrote:
> So to make sure it's archived in the mailing
> list, here's what I've gathered is now the way to go (same idea for
> getting GRASS support fully functional in QGIS, by the way):
> - build and install GDAL WITHOUT GRASS support
> - build and install GRASS
> - download the separate gdal-grass plugin that is available at the
> gdal site
> (as of this writing, that's http://www.gdal.org/dl/gdal-grass-1.3.1.1.tar.gz )
> and compile that, and the make install process in that directory will
> insert just the GRASS driver into your existing GDAL tree
This is documented in the GRASS Wiki:
http://grass.gdf-hannover.de/twiki/bin/view/GRASS/WebHome
-> How to compile/install GRASS and QGIS with GDAL/OGR Plugin
http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassQgisGdalOgrPlugin
Best
Markus
More information about the grass-stats
