[STATSGRASS] Problem with gmeta6() in spgrass6.
Roger Bivand
Roger.Bivand at nhh.no
Tue Jun 20 05:08:45 EDT 2006
On Tue, 20 Jun 2006 Seppo.Kaitala at fimr.fi wrote:
> Hello,
> We are having problem with importing region data from GRASS (6.1) to R
> (2.3.1) with gmeta6(), which in turn makes it impossible to export the
> processed data back to GRASS. Here's our region:
> projection: 3 (Latitude-Longitude)
> zone: 0
> datum: wgs84
> ellipsoid: wgs84
> north: 66N
> south: 53N
> west: 9E
> east: 31E
> nsres: 0:00:30
> ewres: 0:01
> rows: 1560
> cols: 1320
> And gmeta6() gives 6 "NAs introduced by coercion" warnings, replacing
> north, south, west, east, nsres and ewres with NAs. I suspect it is
> because it tries to import them as numeric (but why?).
Because it is not written to parse non-numerical values. This may be
changed, but in fact just throwing an error will be enough. Why - because
the values are simply not used anywhere in code, that is the values
returned by gmeta6() are not required in any of the other functions.
I can look at this sometime (late August earliest), but spgrass6 is
available for anonymous CVS from the r-spatial sourceforge site, so anyone
can contribute a fix if need be - see ?"DMS-class" in sp for some ideas,
although it will not accept the data as formatted in g.region -p output.
> However, replacing them with numeric values by hand doesn't help much,
> exporting with rast.put6() still doesn't work properly. Any hints?
There is no reason why rast.put6() should not work, unless the first
argument passed to it is malformed because the (wrong) values returned by
gmeta6() are being used (for constructing a GridTopology object, for
example).
Could you explain in more detail why you have problems? traceback() after
an error message from rast.put6()? sessionInfo() so that the package
versions are known?
Roger
> Przemyslaw Bojczuk
> and
> Seppo Kaitala, Ph.D., Scientist
> Dept. of Biological Oceanography
> Finnish Institute of Marine Research
> Erik Palménin aukio 1 (P.O. Box 2)
> FIN-00561 Helsinki, Finland
> tel. +358-9-61394417 fax +358-9-323 2970
> mobile +358-400-609-269
> E-mail:Seppo.Kaitala at fimr.fi
> statsgrass mailing list
> statsgrass at grass.itc.it
> http://grass.itc.it/mailman/listinfo/statsgrass
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats
