[STATSGRASS] Raster time series and R - timezones?
Markus Neteler
neteler at itc.it
Wed Jun 21 12:05:35 EDT 2006
On Wed, Jun 21, 2006 at 10:04:28AM +0200, Roger Bivand wrote:
> On Wed, 21 Jun 2006, Hamish wrote:
> > Markus wrote:
> > > > > > strptime(mytime,"%d %b %Y %H:%M:%S")
> > > > > [1] "2006-04-07 10:30:00"
> > > > > -> UTC lost
> > > > add %Z to include timezone?
> > > This is the lacking feature... strptime doesn't care of %Z.
> > Then it's R's strptime() which has a problem.
> > I found %Z on the glibc <time.h> strptime() help page.
> > Maybe it is best to write a little bash script using `date --iso` or
> > tiny C program using time.h's strptime() to pre-process the data?
> > I take it R lets you do system() calls somehow.
> > versus fighting R for a feature which doesn't exist.
> > does R have a gmtime() or localtime() equivalent?
> The problems seem to stem from R trying to work cross-platform and
> cross-locale.
For me it would be sufficient to have R operating in UTC,
then I would not have the current problems.
> The help page for strptime() does say that %Z and %z are
> output only.
Right (which is a non-feature IMHO).
> It is an interaction of platform (and platform libraries) and
> the way locales are represented on that platform and the locale affecting
> the R process. There have been threads a number of times on this, also
> because locales affect i18n etc. Maybe it is time to draft a short message
> to R-help:
> Sys.getlocale()
> sessionInfo()
> mytime <- "7 May 2006 10:30:00 UTC"
> t0 <- strptime(mytime,"%d %b %Y %H:%M:%S")
[1] "2006-05-07 10:30:00"
-> UTC info lost
> attributes(t0)
$names
[1] "sec" "min" "hour" "mday" "mon" "year" "wday" "yday" "isdst"
-> maybe this could be parsed for ISOdatetime?
> # how to get mytime into ISOdatetime() ?
> t1 <- ISOdatetime(t0$year+1900, t0$mon+1, t0$mday, t0$hour, t0$min,
> t0$sec, tz="UTC")
> t1
> attributes(t1)
> Are we getting anywhere??
> Roger
I have now tried another way: Import of CSV into PostgreSQL
to later use Rdbi to fetch the data:
DROP TABLE modis_lst_meteo;
CREATE TABLE modis_lst_meteo (
station varchar(5),
east double precision,
north double precision,
LST double precision,
obs_data timestamp with time zone,
modis_map varchar(40)
SET DATESTYLE To European;
COPY modis_lst_meteo FROM stdin USING DELIMITERS ';';
[input data ordered by station,date]
A query result (where station='53') is this:
53;2000-03-08 11:30:00+01;modis_lst1km2000038.LST_Day_1km.filt
53;2000-03-08 14:30:00+01;aqua_lst1km2000038.LST_Day_1km.filt
53;2000-03-08 23:30:00+01;modis_lst1km2000038.LST_Night_1km.filt
53;2000-03-08 02:30:00+01;aqua_lst1km2000038.LST_Night_1km.filt
53;2000-03-09 11:30:00+01;modis_lst1km2000039.LST_Day_1km.filt
53;2000-03-09 14:30:00+01;aqua_lst1km2000039.LST_Day_1km.filt
53;2000-03-09 23:30:00+01;modis_lst1km2000039.LST_Night_1km.filt
53;2000-03-09 02:30:00+01;aqua_lst1km2000039.LST_Night_1km.filt
53;2000-03-10 10:30:00+01;modis_lst1km20000310.LST_Day_1km.filt <-switch
53;2000-03-10 14:30:00+01;aqua_lst1km20000310.LST_Day_1km.filt <-no-switch?
53;2000-03-10 22:30:00+01;modis_lst1km20000310.LST_Night_1km.filt <-switch
53;2000-03-10 02:30:00+01;aqua_lst1km20000310.LST_Night_1km.filt <-no-switch?
53;2000-03-11 10:30:00+01;modis_lst1km20000311.LST_Day_1km.filt
53;2000-03-11 14:30:00+01;aqua_lst1km20000311.LST_Day_1km.filt
53;2000-03-11 22:30:00+01;modis_lst1km20000311.LST_Night_1km.filt
53;2000-03-11 02:30:00+01;aqua_lst1km20000311.LST_Night_1km.filt
53;2000-03-12 10:30:00+01;modis_lst1km20000312.LST_Day_1km.filt
So:
- 11:30:00+01 is changed to 10:30:00+01
- 14:30:00+01 and 02:30:00+01 remain ?!
- 23:30:00+01 is changed to 02:30:00+01
and it happens 2000-03-10 (a bit early in the year? Can't find the date
of daylight saving switch for 2000 in Europe right now).
Aah, a few days later in the DB:
53;2000-03-25 10:30:00+01;modis_lst1km20000325.LST_Day_1km.filt
53;2000-03-25 14:30:00+01;aqua_lst1km20000325.LST_Day_1km.filt
53;2000-03-25 22:30:00+01;modis_lst1km20000325.LST_Night_1km.filt
53;2000-03-25 02:30:00+01;aqua_lst1km20000325.LST_Night_1km.filt
53;2000-03-26 10:30:00+02;modis_lst1km20000326.LST_Day_1km.filt <- +2h
53;2000-03-26 15:30:00+02;aqua_lst1km20000326.LST_Day_1km.filt <-switch
53;2000-03-26 22:30:00+02;modis_lst1km20000326.LST_Night_1km.filt
53;2000-03-26 03:30:00+02;aqua_lst1km20000326.LST_Night_1km.filt <-switch
Not really convincing. Moreover frightening that the DST switch
isn't happening at the same day in PostgreSQL for different times
of the day. 2000-03-26 sounds reasonable to me, but the morning time
was already (partially) changes earlier the month. Uffa.
Maybe I am missing something essential here (PostgreSQL 8)?
Best would be to set R somehow to UTC and to not do anything with
daylight saving time since I don't need it.
Markus
More information about the grass-stats
