SV: [STATSGRASS] spgrass6 rastget6 bug??
Roger Bivand
Roger.Bivand at nhh.no
Thu Mar 23 06:41:17 EST 2006
Please try the command by hand within R with debug(rast.get6). When rast.get6() calls other interface functions, please enter debug(that_function) to follow the trail all the way back to the command that is giving the progress report. If the annoying progress percentages are on stderr, probably they can be caught somewhere, but first we need to see where they are coming from and stop them.
Roger Bivand, NHH, Helleveien 30, N-5045 Bergen,
-----Opprinnelig melding-----
Fra: statsgrass-admin at grass.itc.it på vegne av Ulrich Leopold
Sendt: to 23.03.2006 10:58
Til: statsgrass at grass.itc.it
Emne: [STATSGRASS] spgrass6 rastget6 bug??
Dear list,
I am trying to automate some statistics with the help of the latest version of
spgrass6 and rastget6. The problem I encounter is that when I load maps from
within GRASS-6.0.1 with
alzette <- rast.get6(c("surface_alzette_sealed", "precip_obkp"), cat=c(TRUE,
FALSE))
it shows a progress which only counts to 96%. Then this number blocks the next
command in a script. The only way to get around it is to press return on the
command line which I cannot do in the script.
Is this a bug. And if yes. Do you know any work arounds?
Any help appreciated.
Cheers, Ulrich
statsgrass mailing list
http://grass.itc.it/mailman/listinfo/statsgrass
URL: http://lists.osgeo.org/pipermail/grass-stats/attachments/20060323/eb95a97e/attachment.html
More information about the grass-stats
