[STATSGRASS] gstat on mac osx with grass
epi fanio massimodisasha at yahoo.it
Sat Mar 25 08:56:59 EST 2006
hi !!!
i'm new to this list,
i've a problem with gstat :
i'm on a mac osx 10.4.5
i've download a source code of gstat-2.4.0 from here :
    http://www.gstat.org/download.html
i've unzipped the file on my desktop
then  in my  shell (bash)   :
   >>>>>>>      cd /Users/epi/Desktop/gstat-2.4.0/
and :
   >>>>>>>     ./configure --with-grass6=/usr/local/grasslib/
the result is :
loading cache ./config.cache
checking for gcc... (cached) gcc
checking whether the C compiler (gcc  ) works... yes
checking whether the C compiler (gcc  ) is a cross-compiler... no
checking whether we are using GNU C... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for ranlib... (cached) ranlib
checking for a BSD compatible install... (cached) /usr/bin/install -c
checking how to run the C preprocessor... (cached) gcc -E
checking for ANSI C header files... (cached) yes
checking for gcc option to accept ANSI C... (cached)
checking for function prototypes... yes
checking for working const... (cached) yes
checking for MS-DOS/djgpp... (cached) no
checking for flex... (cached) flex
checking for yywrap in -lfl... (cached) yes
checking for bison... (cached) bison -y
checking for stat.h... (cached) no
checking for unistd.h... (cached) yes
checking for getopt.h... (cached) yes
checking whether time.h and sys/time.h may both be included...
(cached) yes
checking for 8-bit clean memcmp... (cached) yes
checking for vprintf... (cached) yes
checking for strstr... (cached) yes
checking for strtod... (cached) yes
checking for strtol... (cached) yes
checking for popen... (cached) yes
checking for drand48... (cached) yes
checking for gettimeofday... (cached) yes
checking for getopt... (cached) yes
checking whether byte ordering is bigendian... (cached) yes
checking for main in -lncurses... (cached) yes
checking for gdImagePng in -lgd... (cached) no
checking for gdImageGif in -lgd... (cached) no
checking for main in -lnetcdf... (cached) no
checking for QRfactor in -lmeschach... (cached) no
checking for G_gisinit in -lgis... (cached) no
checking for main in -lgsl... (cached) no
creating ./config.status
creating makefile
creating src/makefile
creating libcsf/src/makefile
creating doc/tex/makefile
creating src/config.h
src/config.h is unchanged
but when i try to make :
  >>>>>>   make
i've this error :
(cd libcsf/src; make)
gcc -c -O -I../include -DHAVE_CONFIG_H  _getcell.c
In file included from ../include/csf.h:13,
                  from _getcell.c:9:
../include/csftypes.h:161:4: error: #error BYTE ORDER NOT SPECIFIED
(CPU_LITTLE_ENDIAN or CPU_BIG_ENDIAN)
make[1]: *** [_getcell.o] Error 1
make: *** [libcsf/src/libcsf.a] Error 2
powerbook-g4-12-di-epifanio:~/Desktop/gstat-2.4.0 epi$
if i try without    <----with-grass6=/usr/local/grasslib/>
in the ./ command, i've the same error!
how can i do?
can you help me ?
thanks to oll  !!!
Massimo.
More information about the grass-stats mailing list
