[STATSGRASS] R/grass, numerical instability/kriging
Tomas Lanczos lanczos at t-zones.sk
Wed Oct 18 10:55:01 EDT 2006
Hello,
finally I solved it - one of the points were duplicated another two points
were too close to each others, now it's perfect, thank You. However, is
there a common rule for e.g. selecting resolution for the given smallest
distance the measurments?
regards
Tomas
> Tomas,
> There's a few possible of reasons; the most common ones are
> more than one measurement sharing the same location, or
> insane variogram models in kriging; anothers is perfectly
> correlated predictors, possibly in a local search neighbourhood..
> We need to see more from your case to find out.
> Best regards,
> Edzer
> Tomas Lanczos wrote:
> > Hello,
> > how can I prevent numerical instability in kriging? Using R with
> > grass63, library gstat.
> > Many thanks
> > Tomas
> > statsgrass mailing list
> > statsgrass at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/statsgrass
More information about the grass-stats mailing list
