[STATSGRASS] using R and gstat inside a C module
Markus Neteler neteler at itc.it
Mon Oct 23 14:35:18 EDT 2006
On Mon, Oct 23, 2006 at 07:38:51PM +0200, G. Allegri wrote:
>    Rpad is a really nice tool, I didn't know it. But do you think it could be
>    a way to solve my problem? I need to do gis analysis too, it's not just
>    about dealing with R code... I know client/server isn't an easy subject
>    but it seems to be the only way I can consider to interface the bash
>    scripting code I will produce (I'm abandoning the idea to write a C
>    modulea!!!) in a platform-independent way.
>    Look at this [1]http://les-ejk.cz/?cat=pywps
As far as I know, pywps has been recently integrated with R.
I cc the author (who may be offline for a week) to give
further details.
Markus
>    Giovanni
>    2006/10/23, Roger Bivand <[2]Roger.Bivand at nhh.no>:
>    > On Mon, 23 Oct 2006, G. Allegri wrote:
>    > > Thanks Roger for the complete answer!
>    > > I know it sounds quite strange what I'm trying to do, and maybe it
>    > > isn't the best way to do it.
>    > > What I meant to do is an interactive (through a GUI interface to
>    > > develop) tool to elaborate hydrogeochemical datas about acquifer
>    > > pollution defense. It should be used by an end-user as a Decision
>    > > Support System tool. It will use raster and vector input data to be
>    > > treated with mapalgebra and geostatisitcal analysis. The worst problem
>    > > is that it should be, somehow, platform independent.
>    > If platform-independent, then a client-server model with the client
>    being
>    > a web browser looks attractive. In that case, I would look seriously at
>    > either MapServer (and Tyler Mitchell's book Web Mapping Illustrated) if
>    > most of the user interaction is in map form, or at Rpad:
>    > [3]http://www.rpad.org/Rpad/
>    > Look at [4]http://www.rpad.org/Rpad/InterruptionMap.Rpad
>    > to see a very nice example. You'll need to look at load balancing
>    > carefully, but here the web server and R are running on the server,
>    > producing pages with Javascript for interaction for the user. A lot of
>    the
>    > hard work has already been done, and because of the split between client
>    > and server, you can update the server-side compute engine without the
>    user
>    > needing to install anything.
>    > I think this is as close as you can get - using embedded R will mean a
>    lot
>    > more work, especially with maintenance. Note the comments on the Rpad
>    site
>    > about security, you will need to run the server with care.
>    > R can also be embedded within Apache, but I guess that Rpad is better
>    for
>    > you. To be honest, it might well be worth paying someone with
>    > Javascript/Perl/Apache etc. experience to help, none of these are
>    suitable
>    > for non-specialists if the server is to be kept secure, really, but the
>    > same applies to any client-server model running across the Internet.
>    > Roger
>    > > I'm not a professional programmer, I'm a geologist, and surely it
>    > > would be easiar to work with scripting then C coding, but it gets
>    > > harder to develop the "wizard" interface...
>    > > In regard using R in an interactive way: I would like to "grep" simply
>    > > the output (as standard output or ascii file) and  then use it for my
>    > > purposes.
>    > > Could you suggest me a way to implement this "stange" architecture?
>    > > Giovanni
>    > > P.S.: I'm considering the web interface way too...
>    > > 2006/10/23, Roger Bivand <[5]Roger.Bivand at nhh.no >:
>    > > > > I need to use R and gstat functionalities inside a module I'm
>    writing.
>    > > > Why? What OS/platform? Unless you are doing something very peculiar,
>    you
>    > > > will waste an inordinate amount of time, where a shell script will
>    get you
>    > > > there simply and be several orders of magnitude easier to debug. Be
>    aware
>    > > > that R functions are often best used interactively because user
>    choices
>    > > > and error conditions do matter.
>    > > > > To embed R in a C program libRmath should be used.
>    > > > No, that is just to use the math functions. See Section 8.1 in
>    > > > [6]http://cran.r-project.org/doc/manuals/R-exts.html
>    > > > for Unixalikes (building R as a shared library, most likely
>    libR.so).
>    > > > > First question:
>    > > > > Is it possible to load gstat package from the R standalone
>    library?
>    > > > Yes, like any package, but why?
>    > > > > Second question:
>    > > > > Is there another way to do it when working inside a GRASS module?
>    The
>    > > > > question raises because, with regard to spgrass6, there's no way
>    to
>    > > > > use it from a module (except by making a shell process call from
>    C)...
>    > > > Well, you can use the GRASS API to populate the appropriate R object
>    > > > structures in C (see the GRASS5 GRASS package C code).
>    > > > > am I wrong?
>    > > > Yes, because you will never (at least for a definition of never
>    being
>    > > > greater than the number of developer hours taken to write and
>    maintain
>    > > > gstat and the R/GRASS interface) be able to do this robustly, taking
>    > > > account of all possible error conditions (identical points passed to
>    gstat
>    > > > for example), and track changes in the different software
>    environments
>    > > > (something that works only with GRASS version x.y.z, R version
>    a.b.c,
>    > > > gstat version d.e.f, sp version g.h.i, etc. There is simply too much
>    being
>    > > > patched for a welded-hood C solution to be worth the development and
>    > > > maintenance cost.
>    > > > By the way, you didn't say what you want to do that needs this level
>    of
>    > > > automation; if you had, it might be easier to understand your very
>    strange
>    > > > design choices and resource commitments.
>    > > > > Thanks,
>    > > > > Giovanni
>    > > > > _______________________________________________
>    > > > > statsgrass mailing list
>    > > > > [7]statsgrass at grass.itc.it
>    > > > > [8]http://grass.itc.it/mailman/listinfo/statsgrass
>    > > > Roger Bivand
>    > > > Economic Geography Section, Department of Economics, Norwegian
>    School of
>    > > > Economics and Business Administration, Helleveien 30, N-5045 Bergen,
>    > > > Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
>    > > > e-mail: [9]Roger.Bivand at nhh.no
>    > Roger Bivand
>    > Economic Geography Section, Department of Economics, Norwegian School of
>    > e-mail: [10]Roger.Bivand at nhh.no
> References
>    Visible links
>    1. http://les-ejk.cz/?cat=pywps
>    2. mailto:Roger.Bivand at nhh.no
>    3. http://www.rpad.org/Rpad/
>    4. http://www.rpad.org/Rpad/InterruptionMap.Rpad
>    5. mailto:Roger.Bivand at nhh.no
>    6. http://cran.r-project.org/doc/manuals/R-exts.html
>    7. mailto:statsgrass at grass.itc.it
>    8. http://grass.itc.it/mailman/listinfo/statsgrass
>    9. mailto:Roger.Bivand at nhh.no
>   10. mailto:Roger.Bivand at nhh.no
Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
More information about the grass-stats mailing list
