[STATSGRASS] kriging results not within range of original data
Edzer J. Pebesma e.pebesma at geo.uu.nl
Tue Oct 31 15:47:09 EST 2006
Hi Carlos,
that is correct, and due to the fact that kriging weights are not
constrained to be in [0,1]. In fact, they do become negative and may be
larger than 1. Consider as alternatives either inverse distance weighted
interpolation, or some form of constrained kriging (although I wouldn't
know where to get the latter).
Edzer
Carlos "Guâno" Grohmann wrote:
> Hello,
> I'm dong some kriging of SRTM data, and noted that the kriged results
> don't lie within the range of the original data. It is not too far
> from the original, but there is a difference.
> original dem:
> Data attributes:
>     band1
> Min.   : 634.0
> 1st Qu.: 759.0
> Median : 814.0
> Mean   : 856.5
> 3rd Qu.: 923.0
> Max.   :1312.0
> resampled dem:
>   var1.pred
> Min.   : 633.2
> 1st Qu.: 759.2
> Median : 814.3
> Mean   : 856.4
> 3rd Qu.: 923.5
> Max.   :1307.4
> I konw thatt small deviations from the values range can occur, but I
> was looking for some deeper explanation on this. If someone could
> point me out any literature I can refer to, I will be thankful.
> Carlos
More information about the grass-stats mailing list
