[STATSGRASS] Another problem with kriging (gstat)
Jarek Jasiewicz
jarekj at amu.edu.pl
Wed Sep 13 08:14:08 EDT 2006
Edzer J. Pebesma napisał(a):
> Jarek,
> Eight of your data are collocated:
> > zerodist(rf)
> [,1] [,2]
> [1,] 46 47
> [2,] 136 142
> [3,] 145 147
> [4,] 150 152
> [5,] 200 201
> [6,] 213 214
> [7,] 328 333
> [8,] 332 334
> Removing them solves the problem. Try for example:
> krig=krige(cs~1, loc=rf[-zerodist(rf)[,1],], newdata=sg, model=frfit)
> spplot(krig[1],col.regions=bpy.colors())
> in which case you (arbitrarily) remove the first of each colocated pair.
> Edzer
> Jarek Jasiewicz wrote:
>> Hi
>> It is outside statgrass because of attachment
>> here are data and what I did (only simple model, without anisotropy
>> spherical variogram etc) but I tested it on other variograms and with
>> anisotropy, distance and so on, as well
>> first data:
>> rf - with two slots: l (lenght) and cs (cosine) of the feature
>> sg - spatial grid dataframe on witch I try to do prediction
>> first variogram:
>> vr=variogram(cs~1, locations=rf)
>> next fitting
>> frfit=fit.variogram(vr, vgm(1650, "Sph", 7000, 11000))
>> and the last kriging
>> krig=krige(cs~1, loc=rf, newdata=sg, model=vrfit)
>> after imaging
>> image(krig) the artefact will be visible well
>> by the way: I aware that that data are not well suitable for kriging
>> regards
>> Jarek Jasiewicz
thanks a lot
Jarek
More information about the grass-stats
