[STATSGRASS] compare several maps
Jarek Jasiewicz jarekj at amu.edu.pl
Thu Aug 9 12:29:38 EDT 2007
Carlos "Guâno" Grohmann wrote:
> Sure, sorry about that.
> I am analyzing various methods of calculation of surface roughness. So
> I will have several maps, produced with different methods, at
> different scales and with different datasets.
> All maps are calculated with moving-window procedures. I'll have maps
> calculated  with neighborhoods of 3,5,7,9,11,.. pixels, over DEMs with
> 5,10,25,50,90 meters resolution, using probably three different
> methods.
> So I'll end up with tens of maps! I was wondering what would be a good
> approach to compare them. I was thinking to rescale all maps to a
> common range (say, 0-255) first, and then compare.
> I guess it makes sense to compare like this:
> DEM_10m - Window_Size_3x3 - method A/B/C
> DEM_10m - Window_Size_5x5 - method A/B/C
> and so on for each dem resolution and window size.
> carlos
>>> What do you guys think is a good approach to compare several raster
>>> maps at the same time? correlation matrix? some graphical output?
>>> density plots?
>>> cheers
>>> carlos
>> well, give us more detail what do you need
difficult question, correlation matrix seems not to be good method, if
you want to compare data produced with different resolution and
different moving window (i.e pixel with greater area will have in all
paces teh same value will cover  group of small pixels with compleatly
deferent walue)
maybe autocorellation in individual map will  be  interesting parameter
density plots also seems interesting
More information about the grass-stats mailing list
