[STATSGRASS] Re: [R-sig-Geo] R + GRASS in win XP
Roger Bivand
Roger.Bivand at nhh.no
Fri Aug 31 18:37:36 EDT 2007
On Fri, 31 Aug 2007, Agustin Lobo wrote:
> Roger,
> Roger Bivand escribió:
>> On Sun, 26 Aug 2007, Roger Bivand wrote:
>> It was a combination of path variables with spaces and the apparent need
>> to call GRASS commands with *.exe extensions from within R in the GRASS
>> shell under GRASS Tools (QGIS 0.8.1). From spgrass6-0.4-1, QGIS/msys/GRASS
>> is supported - package revision just submitted to CRAN.
>> Roger
> what does "QGIS/msys/GRASS is supported" mean? Can R be used as a Qgis
> pluggin? Also for linux?
No, only that R will work when run in the GRASS Tools -> GRASS shell
inside QGIS under Windows with the MSYS-built GRASS modules. I do not know
whether the QGIS Linux version includes a similar GRASS Tools, but if so,
the shell ought to run R in the normal way. Running library(spgrass6)
gives access to GRASS.
Roger
> Thanks
> Agus
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats
