[STATSGRASS] gmeta6() returns empty string
Tilmann Steinmetz
tilmann.steinmetz at geo.uni-halle.de
Tue Feb 27 14:36:08 EST 2007
I am having difficulties getting the region environment settings from grass
into R using gmeta6() (see output below).
The installed packages are as follows:
> sessionInfo()
R version 2.4.0 (2006-10-03)
i386-portbld-freebsd5.4
locale:
C
attached base packages:
[1] "methods" "stats" "graphics" "grDevices" "utils" "datasets"
[7] "base"
other attached packages:
spgrass6 rgdal maptools foreign sp
"0.3-6" "0.5-6" "0.6-8" "0.8-18" "0.9-8"
When I start R from within the Grass (6.2.1) shell (with spearfish6
location)
I encounter the following:
> library(spgrass6)
Loading required package: sp
Loading required package: maptools
Loading required package: foreign
Loading required package: rgdal
Geospatial Data Abstraction Library extensions to R successfully loaded
> g.region -d
Error: object "g.region" not found
> gmeta6()
ERROR: default region is invalid
line 11: <top: 1>
/libexec/ld-elf.so.1: g.proj: Undefined symbol "G_gettext"
Error in if (is.na(projstr)) uprojargs <- projstr else uprojargs <-
paste(unique(unlist(strsplit(projstr, :
argument is of length zero
The problem seems to arise from an empty default region in GRASS:
> system("g.region -d")
line 11: <top: 1>
> traceback()
2: getLocationProj()
1: gmeta6()
I can go back to GRASS and say g.region -p which shows me the region
settings
alright and when I call g.region -d it returns an empty string. This is most
peculiar since I double-checked DEFAULT_WIND is there and non-empty. This
behaviour is the same for my own location irrespective of projection or
whatever. (I just reinstalled Spearfish6 to make sure its not something with
access permissions or such).
I'd be most grateful for any help with this. I even tried to hardcode my
projection into spgrass6 in order to get this to work (unsuccessfully
though)
But I could live with that for the moment. Any hints?
Thanks,
Tilmann
More information about the grass-stats
