[STATSGRASS] GRASS+R: problem with gmeta() command
Mauricio Zambrano
hzambran.newsgroups at gmail.com
Wed Jul 25 07:54:06 EDT 2007
Thanks a lot Martin.
The problem was in the library that I had loaded, because I had loaded
the library GRASS with the command "library(GRASS)", as is read
yesterday in the web-page :
http://www.geog.uni-hannover.de/grass/statsgrass/grass_r_interface.html#Using_GRASS_R
but now i realized thath the right instructions are int the web page:
http://www.geog.uni-hannover.de/grass/statsgrass/grass6_r_install.html
In fact, when I put "library(spgrass6)" everything was right:
Loading required package: sp
Loading required package: maptools
Loading required package: foreign
Loading required package: rgdal
Geospatial Data Abstraction Library extensions to R successfully loaded
> gmeta6()
gisdbase /home/hzambran/GrassData/UTM/psad56_h19s
location chile
mapset v_region
rows 10034
columns 7640
north 6456370
south 6205510
west 237658
east 428667
nsres 25.00100
ewres 25.00118
projection +proj=utm +south +zone=19 +a=6378388 +rf=297 +no_defs
+towgs84=-288.000,175.000,-376.000
Thanks a lot !.
Mauricio
More information about the grass-stats
