[STATSGRASS] GRASS+R: problem with gmeta() command
Markus Neteler
neteler at itc.it
Wed Jul 25 09:41:19 EDT 2007
Markus Neteler wrote:
> On Wed, Jul 25, 2007 at 02:19:59PM +0200, Roger Bivand wrote:
>> On Wed, 25 Jul 2007, Mauricio Zambrano wrote:
>>> Thanks a lot Martin.
>>> The problem was in the library that I had loaded, because I had loaded
>>> the library GRASS with the command "library(GRASS)", as is read
>>> yesterday in the web-page :
>>> http://www.geog.uni-hannover.de/grass/statsgrass/grass_r_interface.html#Using_GRASS_R
OK, the GRASS 5 stuff is moved out now to a new page and this page:
http://grass.itc.it/statsgrass/grass_r_interface.html
contains references only. It will reach the Hannover mirror within 24h.
Markus
View this message in context: http://www.nabble.com/GRASS%2BR%3A-problem-with-gmeta%28%29-command-tf4141495.html#a11782908
Sent from the Grass - Stats mailing list archive at Nabble.com.
More information about the grass-stats
